2024-10-10
07:26 PM
2024-10-12
07:12 AM
Does someone remember if there is a way to create a property within the "Property Manager" that renders the same set of values as the ones using the "Building Material (ALL)" parameter within the Schedule feature?
Solved! Go to Solution.
2024-10-12
07:20 PM
2024-10-13
01:56 AM
Hi David, the "Building Materials (ALL)" general parameter is not available directly in properties.
But it is available in the IFC Property Mapping for the translators, so you can create a mapping rule for each element, see below:
2024-10-12
07:20 PM
2024-10-13
01:56 AM
2024-10-12 07:42 PM
Thanks, Jaime!
I totally forgot that workaround... even having spent hundreds of hours in the past mapping properties using the translators.
I hope a more robust harmonization and automation is implemented in the future.
2025-10-13 09:37 AM
This is almost good, but here comes the next step:
I would like to split the ; separated string into bullet point list.
Any idea how to do that?
Basically I would like to do a wall type list and list the wall buildup (building materials) as a bullet point list, simply because this ; separated list is very hard to read.
Any help would be much appreciated.
