Project data & BIM
Can anyone attach a void Archicad 18 file please?
Paopao
I think I have messed up my Archicad somehow, now all objects and layers are random, I would like to try to load an empty file and store it as standard before having to reinstall it. My files seem corrupt and I am in the middle of a project.
Archicad 18 English please, possibly a Mac user...
Thanks
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
7 REPLIES 7
Try opening a New file while holding down the Option key - New will change to "New and Reset All"
Paopao
Thanks Stuart, I will do that.
Is it my idea or in the past whenever I would put an object (slabs, columns, image, etc...) the layer was chosen automatically? Because it doesn't happen to me now, whenever I have to use one of the objects I need to create a specific layer now. I have been away from Archicad for a few years, forgive me about the lame question.
David Shorter
Any object or element can be placed on any layer. Usually the template which comes with ARCHICAD has particular layers for particular elements. Wall to a Wall layer, Slab to a slab or floor layer etc but this is only a guide.
Layers are there to help you organise your model....
Hope this helps
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
http://www.masterscript.nl/epages/78066077.sf/en_GB/?ObjectPath=/Shops/78066077/Products/101
Paopao
Hope this helps
Thanks, I knew it but I need a model
Paopao
Thanks! I think it is precisely what I needed!
Your welcome. This is the only Template I use.
"Clean Template is a standard ArchiCAD 18 and 19 template, but without any attributes, libraries, views, layouts, project preferences and so on. It is perfect to start building your own template from scratch. Additionally you can also use it to open ArchiCAD fast for merging DWG or IFC."
