Project data & BIM
Can you change parameters in multiple viewsets at one time?
Is there anyway to change the parameters of all of the perspective view sets at one time? Lets say I add a layer, change my output size, turn shadows off.....I have to open each view set (ctrl . to stop generation, then "stop" to keep it from rendering) then change the parameter, then redefine with the new parameter. Now repeat, 3, 8, 12 times however many perspectives the project has. There has to be a global change for view sets and I am must missing it.
Education requested.
Thanks wise ones.
5 REPLIES 5
TomWaltz
yes and no:
Layers: If you always assign a layer combination to your Views, you can easily redefine them on the fly bu altering the layer combination.
Shadows: these are controlled by the Section Marker. They are either on or off. You cannot re-define them by view at all. OR, if you are using the 3D window, then there is no "named combination" of 3D Window settings. I guess either way, you would have to manually re-define your Views.
Output size: not sure what you mean. Where are you defining this to begin with?
Tom Waltz
By output size I mean in the 3D window settings. Isn't there a way to change 3D window setting, display options, photo rendering setting....across all of the viewsets?
Djordje
Set everything as you wish, select all of the views that you want updated, select Update from the flyout arrow in the upper right corner.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
that won't redefine all of the perspectives to the set camera shot as well?
Link
Perspectives remember the settings current at the time they were saved or redefined. If you have many perspectives, simply change the photorendering settings and redefine the views all at once. Otherwise create separate viewsets for each photo rendering setting. Basically, everything under the Image menu is stored with views. Shadows are a function of the S/E tool, not views, but as per photorenderings, their state will be remembered at the time the views are created/redefined.
I create two S/E's for each view in my templates, so that the whole system can remain fully automated.
Link.
