‎2022-10-10 06:10 PM
I have created an expression for the zone stamp to show the elevation, but it misses two things:
1. I try to add a + sign in front of the number to show it is upper than zero (and it is not showing on the stamp)
2. I try to add to show CM at the end of the number but it says syntax error.
How can i show these two on the zone stamp?
Thanks
Solved! Go to Solution.
‎2022-10-11 12:38 PM
Try to import this property
‎2022-10-11 10:54 AM
Hi Qingdom,
Try like this with string data type: CONCAT ( "+"; STRCALCUNIT ( {Property} ) ;"CM")
David
‎2022-10-11 11:02 AM
Still not working, it gives syntax error in expression.
‎2022-10-11 11:07 AM
Did you change the data type and did you paste the property (bottom elevation to project zero)?
‎2022-10-11 11:10 AM
Yes, see picture
‎2022-10-11 11:12 AM
You have to remove the brackets { }.
‎2022-10-11 11:14 AM
Still no succes 😄
‎2022-10-11 11:40 AM
I will do like this
"Sorry in french"
IF ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} > 0 cm; CONCAT ( "+"; STRCALCUNIT ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} ); " cm" ); CONCAT ( STRCALCUNIT ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} ); " cm" ) )
‎2022-10-11 11:45 AM
Yes, something with IF i think i need. Still it doesn't work...
‎2022-10-11 12:13 PM
You are in String data type !
