Project data & BIM
Change marker archiveing
I still feel the change/revision management is a total mess and unnecessary overcomplicated but let it be as it is functional.
I don't get one thing: What is happening with the change markers after I close the Issue?
I have ~25 changes placed over more than 100 layouts and 300 views. Big project, many changes. I did archive the changes but I don't want to delete them. I want to hide them.
Do I really need to open all views one-by-one and put the change markers to a hidden layer?
Isn't it should be done globally with a single click? What is the point in archive then?
12 REPLIES 12
Achille Pavlidis
I'm having the same issue.
Once there are a lot of changes the "Show revision clouds of latest revision only" doesn't seem to work anymore...
Only show all / show none seems to work. But I noticed that many times when a layout has some changes that it should not have in the current issue (because they are archived for example), then when those changes are manually deleted from the layout, then even the show all/none revision clouds ceases to work...
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Daniel Kovacs
Hello Everyone,
I have checked, and this issue should have been solved in the latest update of ARCHICAD 20, and the released version of ARCHICAD 21. If you still experience this issue (or something similar), you should contact your local reseller, so that they can check it out for you (maybe it is a new bug, or the issue was just partially fixed).
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
Hi
I can report now that there's a bug at least in ArchiCAD 22 with this. Issue is:
- I have new revision where i have specified that no markers should show. (kind of last revision of the project)
- I want to show only some of the changes is change list on layout table so I have selected only those for that layout.
--> Problem is that only THOSE the markers are hidden that ARE in that layout. But all other markers are NOT hidden. This has been quite a strange issue that have bothered me a long time but now i finally figured out what's going on. Haven't yet tested if this exists on later versions as well. (this particular project has started couple of years ago).
