2023-12-21
02:55 PM
2023-12-21
09:15 PM
Hello, good afternoon everyone
I am trying to generate a list of pieces of beams and columns, the problem is generated when joining two pieces of the same type, which in the drawing the rope or blue line is until the end of the section as seen in the image, but in the The list discounts that overlap, which is 38mm, so all the profiles with overlap discount those 38 mm. I have tried everything but nothing works for me. This list is to be entered into a profile cutting machine.
If you could help me please, most likely I must add some type of additional command to the scheme, I tried roundup and all its alternatives but it adds it to the entire profile so it doesn't work.
thank you
2023-12-21 03:06 PM - edited 2023-12-21 03:10 PM
You could use expressions to add the missing information.
The logic might be to create:
PS
I edited the post title to English.
another Moderator
2023-12-22 03:25 PM
The problem I have is that I have not yet mastered adding functions to the diagrams, what I do know is that in my ArchiCAD I do not have the overlap option
2023-12-22 04:27 PM
Then you either need to get some training or start by reading the manual.
another Moderator
