Read more
Project data & BIM
Custom door leaf displays incorrectly as a flat panel door in a schedule
I have a pocket door (#D09) with a custom door leaf that will not display correctly in the schedule. All of the doors have a "Lynden Alki" custom door leaf, however the pocket door shows a plain, flat panel door in the schedule. It is the standard Graphisoft pocket door object "D1 Pocket 27" and it appears correctly in 3D or section views (from both sides), so I'm not sure what's going on or how to fix it. The handle does show correctly. Any ideas how to fix this?
Operating system used: Windows 10.0.19045
AC27 USA - build 5003
HP ZBook 15 G6
Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM
Windows 10 Pro
0 REPLIES 0
Setup info provided by author
