2004-04-07
11:55 AM
2023-05-30
01:06 PM
Rubia Torres
2004-04-11 10:14 AM
Tom wrote:I have done this several times - always very apprehensively - and not lost anything thank goodness.
All this is fine information. However, what I want to know is does AC or does it not purge supposedly "unused layers" that actually have any objects, lines, or anything else on it. It appears to me it does. If it does, the delete unused layers function should be at least named something else to prevent confusion and loss of work.
2004-04-11 03:42 PM
Tom wrote:tom
2004-04-16 01:56 AM
2004-04-16 08:37 AM
Tom wrote:Yes, each tool does have its default layer; whether the layer will be created depends on the tool (some APIs, like Construction Grid, can create their layer if it is missing) but in general you will get a warning that a layer in missing and an option to choose a different one.
Also, does each tool have a default layer? If I delete that layer, then use the tool, will it automatically default to that tool layer and create the layer, or just put the object or whatever on the current layer? Will I have to know what the default layer is for each tool, and then create as new if it's been deleted?
Tom wrote:Hmmmm ... are you trying to re-arrange ArchiCAD layers in the AutoCAD fashion? That might be counterproductive, as the layers in ArchiCAD, although called the same, are not the same thing conceptually and functionally. Therefore I would advise you to first get a grip on the system as it is, and then start tweaking.
This has been bugging me. I'm an ex-autodesk desktop user; they did do layers right.
2004-04-16 06:20 PM
2004-08-09 06:34 PM
Tom wrote:Yes, it does!
2004-08-09 06:55 PM
2004-08-09 07:05 PM
Tom wrote:Agreed! AutoCAD won't let you delete anything that is in use -- layers, linetypes, font styles, etc.. I can be annoying if you are having trouble finding the entity that is using the layer/linetype, but it's way better than finding out that ArchiCAD killed layers that had stuff on them.
IMHO, I think the program should not delete any layer with anything on it,
2004-08-09 07:31 PM
2004-08-09 07:46 PM
Tom wrote:What would help when deleting layers with information still on them is to have a dialog box pop up and give you two options:
IMHO, I think the program should not delete any layer with anything on it, and it should automatically put objects or whatever on their default layer is by recreating it if the layer has been purged.
