2024-09-12
07:05 PM
2024-09-16
03:08 AM
what controls the 19.000" to show 1'-7" at bottom of table?
2024-09-13 02:59 AM - edited 2024-09-13 03:00 AM
I don't use imperial but are your calculation units set to feet and inches?
It will probably display the inches in the individual values differently when you do, but the total should be as you want.
2024-09-13 12:31 PM
yes sir imperial is set correctly. the other window & door schedule items show correctly with the exception of W-2D "nominal ht"? it is a "semi-circle" element window and that may have something to do with it, but figured i can still get 1'-7".
2024-09-16 03:34 AM
Sorry, I thought that was a total for some reason, not an actual individual window object.
I have no idea why that one window has the width in feet and inches but the height in inches only, and all of the other windows have the height in feet and inches as well.
