Niranarch
Editing ID in schedules chrashes Archicad
When I edit window ID in schedule archicad crashes always.  Sent bug report.
any clue how to fix it?
Thank you
Niranjan
3 Replies 3
It shouldn't crash, but that doesn't help you much.
Make sure you have the latest update for 28.
Also be sure to follow up the bug report with your local support, take note of the bug number and ask them to investigate it.
Don't expect Graphisoft to get back to you directly.
Niranjan Das Sharma
I did the bug reporting. Have not taken the local support. I will do that.  I have installed the latest updates.
Thank you.
Niranjan Das Sharma
With the one of the updates in V28 this issue was solved but
I found that even in V29, it crashes. I also found that the the default files are not crashing. only the old files.
I also found that it has someting to do with classification.  ( its not how ever crashing with V28)
Saw that classification is missing in the old file. I found this help page to restore
https://support.graphisoft.com/hc/en-us/articles/37623320822801-Why-does-Object-Library-show-unclass...
Did everything but..Subtype classification is not showing what default file is showing!   Earler before resotring the classification file, when i click the tool box menu 'sub type classification mapping'  Archicad was crashing instantly. This stopped when i restored the classificaiton file. It still crashes when i edit window schedule.
while importing V28 file to V29, this is lost! I was supposed to see this i believe
Can someone help to fix this? not sure if i fix, this will be resolved. I am still using 28 because of this crash.
