‎2025-02-10
05:38 PM
‎2025-02-11
06:00 PM
Hello!
Id' like to extract the RGB values I've set on graphic override for the colors of different "composite" building types (walls/floors/roofs) and put the in a schedule. Now I can easily put the 2D Plan Preview of the elements where I can see the colors but I'd like to follow it with the values of RGB for each color. Is there a way to do this? Thank you in advance.
I'll attach a screenshot of what I'd like the final result to be, in it you can see I've created 3 parameters each for RGB.
‎2025-07-30 10:04 AM
Hello Jaime,
while this label would be useful it's not what I was going for. I "solved" my problem the old way, manually imputing the RGB values, for my graphic override section fill colors, by creating a common text parameter for the elements i needed it and adding it as on my schedule. Took me some time, which is what I was hoping to avoid, but got it done. Thanks for your input though!
E
‎2025-07-30
07:59 PM
‎2025-08-03
04:54 PM
Hello
There is a object in Archicad library that you can use to show some pens and their rgb value, but it starting showing from pen 1, to 2, 3.... Very limeted object but it may help you save time
