I am having an issue with multiple Survey Points which became apperent when I exported an .ifc as I got the following warning:
"The project contains multiple Survey Points. Only one will be used for export."
I am only aware of placing one Survey Point, so I am wondering if one or more has been added through import of other objects. Nonetheless, I cannot find these other Survey Points. I just want to delete them so that I am certain the the exported .ifc contains the correct Survey Point.
I have unlocked all layers and view all renovation filters in the 3D window, but I can only find the SP that I have placed using Find & Select. Is there some specific IFC-parameter that I should be using when searching?
I hope someone has a solution for this very frustrating issue.
Thanks!
	AC 27 SWE, 64-bit
Windows 10 PRO
HP ZBook Fury 16 G9 Mobile Workstation, i9-12950HX, Nvidia RTX A4500, 64GB ram
