Fristadm
Finish Schedule
Working on a room schedule for a project. Currently trying to get the wall finishes into the schedule. I have under properties - Zones - North wall finishes set but when I add that field to the schedule all they show up as is ---. I have it set on all the zones but they all show the same thing. I attached photos of the issue as well
Screenshot 2023-05-01 at 10.28.24 AM.pngScreenshot 2023-05-01 at 10.28.39 AM.png
ArchiCAD 25.6005
2 Replies 2
Can you show an image of your schedule criteria and fields?
Copy and paste the image directly into the text you type if you can, rather than use the drag & drop box below.
That way the image shows in the message.
Fristadm
I got it figured out. I was using the pre-made "Room Legend" under surfaces. I redid it under elements and they showed up then.
ArchiCAD 25.6005
