2007-09-27 04:31 PM - last edited on 2023-05-30 12:55 PM by Rubia Torres
2007-09-28 04:05 PM
I have never been able to grasp the idea of working with a lot of layers.im with you but when u work for cities there no choice than follow standards....a lots of layers
2007-09-28 04:51 PM
kliment wrote:Me too (sorry Ben), but I still believe for a half decent template, if you have under 100 layers, you're doing well. Especially for commercial work.
I have never been able to grasp the idea of working with a lot of layers. Just looking at the list Ben gave makes my head dizzy!
kliment wrote:It is good to separate internal and external walls so that we can turn off internal walls in elevation along with all other internal stuff, to reduce rebuild times. It's also required for calculations, for those people who use BIM that deeply.
I try to use only the basic layers. Sometimes for specific projects I add some more. For example why should we use separate layers for External and Internal walls? We can draw different walls with different pens and fills and select them with Find&Select.
kliment wrote:Yes, we all wish for that! Hopefully it won't be too far away!
If there was a folder based layer structure in AC (like in Photoshop) I could use more layers, but at the moment it is too difficult to find the right layer in the list.
kliment wrote:Unless you use XREF Management or the Drawing Tool!
Just a tip: I always start the names of my layers with blank. In this way imported layers form Autocad always list after my layers, because Autocad cannot write blank as a first letter! Also names in Cyrillic list after the Latin ones.
2007-09-28 05:30 PM
2007-09-28 05:51 PM
2007-09-29 03:07 AM
kliment wrote:but if it was organised to your local classification standards it may look less dizzy, no? it might actually be more recognisable!
Link wrote:but there are under 100 layers in my list and it serves all jobs. a specific job might require one or two more specific layers . . .
Link wrote:that may have been true in the past, but walls are pretty processor cheap these days. calculations can be taken from wall type. (i rarely use a simple fill for my wall - composites are more controllable even if they are only one skin.kliment wrote:It is good to separate internal and external walls so that we can turn off internal walls in elevation along with all other internal stuff, to reduce rebuild times. It's also required for calculations, for those people who use BIM that deeply.
Kliment wrote:hence my twelve title layers - they are there to un-dizzy my layer list!
2007-10-10 04:00 AM
2007-10-10 12:48 PM
davezilla wrote:As far as you could, you should change names on layer instead of erase old and create new. Then you got predefined layers for your tools. That is an easy way to start. Ofcause you can do the other way, but then it take more time to make your templatefile.
hey im new to archicad..i was wondering, my office has it own standard layers,could i preset it to archicad? should i erased the previous archicad layer standard ?
2007-10-10 04:22 PM
2007-10-24 03:02 AM
2007-10-25 10:17 AM
