If you want the elements then you will have to copy and paste from the backup file.
This will re-create the layer automatically.
Turn off all other layers in you back-up to make it easier to select just what you need.
Using the Attribute Manager as Lec suggested will re-create the layer but it will not bring any of the model elements with it.
