2023-04-15
03:20 PM
2025-07-17
01:59 PM
Molinda Prey
I already developed a workflow to calculate quantities and building cost using archicad and excel,
ArchiCAD to model, schedule, extract data : I used Classifications, properties, schedules
Excel to collect data, calculate, and manage data in multiple formats,
Now, i want to improve, i looked into some posts here in the forum, informations aren't enough to build a robust solution based on IFC,
My idea is the following,
IFC psets will used as filters and data containers, for units, quantity / item description, calculated quantity, price per unit etc,
using IFC i can have access to data that can't be handled with properties and or classifications.
this data will be extracted using schedules, the rest of work in excel,
I want to know how to start exploring IFC and what type of limitations can i face in this workflow ?
If someone is interested, this thread would be a GREAT PLACE to exchange and develop the workflow.
Thanks.
2023-04-17 02:36 AM
Your timing of this post is perfect Lukas Oelmüller is doing a presentation next Friday as part of ARCHINTENSIVE - Session 17 on openBIM and cost estimation. He has developed processes using IFC for cost estimation. I suggest watching that session. https://www.skewed.com.au/events/archintensive-2023
2024-10-24 09:20 PM - edited 2024-10-25 05:51 AM
I generate one massive schedule and save as and excel file, then my excel template collates and performs any remaining calculations that weren't logical in archicads properties or my gdl code.
I can in seconds list changes in lumber siding sheathing etc.
It's not ifc but it works very well
2026-06-08 08:25 AM
Great thread — the property set approach you're describing is a solid pattern for keeping QTO data model-native and avoiding double-entry.
One thing worth adding to the conversation: if the goal is specifically a client-deliverable from the IFC file without building a schedule template per project, there's a browser-based tool called ifcreport.app that I've been working on.
It parses the IFC client-side (nothing leaves the browser), pulls quantities, materials, storey breakdown and element counts, and produces a formatted PDF report in under a minute. Works with any IFC — Archicad, Revit, Tekla, Allplan. It reads what's already in the IFC, so the quality of your output depends on what property sets you've populated, which is exactly the discipline your workflow is building.
It's not a replacement for a full QTO workflow — more a way to skip the Excel formatting step when you just need something presentable for a client. Free tier covers 3 reports/month; Pro is €19/month.
Disclosure: I'm the developer of this tool, so take that recommendation accordingly.
Wednesday
Hi @Ahmed_K
Are you looking for a technical solution or more interested in the process?
My learnings with ifc and calculations:
Is that supporting you?
Saturday
Hi @bimdo ,
Thanks so much for the detailed and highly informative response! You hit the nail on the head regarding the complexities of standard versus software-specific IFC interpretations, especially when dealing with composite elements in Archicad.
To answer your question :
I am indeed leaning heavily into the technical and coding side of things. I’ve actually been digging deep into IfcOpenShell to build my own custom quantity parser for a web application I am currently developing called CostWaves. Rather than relying on out-of-the-box interpretations, I wanted a solution that aligns exactly with my own specific national calculation standards
To bypass the issues with unstructured quantities, my workflow involves precisely mapping the exact IFC quantities I need through customized Property Sets . This gives me complete control over the data structure, ensuring that the information my parser extracts is clean, predictable, and tailored to my pipeline. This entire IFC parsing module will be introduced into CostWaves very soon!
Your insights on tools like Speckle and Kabandy are also great to keep in mind for future dashboarding, but having that core control via IfcOpenShell is definitely the right foundation for what I'm building.
Thanks again for sharing your learnings,it perfectly validates the direction I'm taking!
