LeeJaeYoung
Is there a way to adjust the gs_bOpeningToZone(boolean) variable by setting it as a property?
I want to control the schedule.
AC27 on window 11
1 Solution
I think I have found the answer.
Click on the 'Merge Options' button and set it to 'Uniform'.
It seems that it might default to 'Unifor or Various' which does not allow you to edit the values in the schedule.
And if you don't see the 'Merge Options' button, you must turn on the main 'Merge Items' option in the schedule settings.
Go to post
8 Replies 8
You can control it now in the schedule as you show in your screen image.
Are you saying you want to see it as a text option rather than a check box?
Or are you saying you can not turn it on/off?
LeeJaeYoung
It can only be viewed in the schedule, but cannot be turned on/off.
AC27 on window 11
You should be able to control settings from the schedule.
If you can't then that probably means the layer combination for the view that you have used to open the schedule, has not got the layer turned on, or those door/wall elements are locked.
But I just had a quick look at a door schedule and I could not alter the door ID or size from the schedule.
I always thought that you could.
I do not use schedules very often, and don't have time to investigate properly at the moment.
I may be able to get back to it later.
LeeJaeYoung
ID is an attribute, so it can be edited.
The size is in two, so editing is not possible.
Door to Zone on/off is a GDL parameter, but it cannot be modified on the spot. (In my experience ^^) It was a question about whether there is another method.
I cannot edit A (width) as it is also a GDL parameter.
AC27 on window 11
I just opened a default template with a default door schedule.
Most but not all parameters are editable in the schedule.
At the moment I am not sure what would stop some parameters from not being editable.
I know the 'door leaf widths' shown in this image is a parameter in the door but it is not one that can be altered by the user anyway - not even in the object, so that is why it is not editable here.
LeeJaeYoung
Today I can't help but thank you. ^^
You put so much effort into giving the answer.
It should be fine. I guess I have no choice but to focus on your every single word because you give me an answer that says no. ^^
Have a happy day today. ^^
AC27 on window 11
LeeJaeYoung
Manual zone cannot be from zone, to zone.
Auto zone becomes from zone, to zone.
Door belongs to the Zone into which it opens seems to work only with the code. ( I posted a question where it is ^^)
And the manual zone doesn't work either. can't it be? ^^
AC27 on window 11
