‎2022-07-20
06:21 PM
‎2023-05-19
11:51 PM
Gordana Radonic
1. Only 침실3 (room 3) appears in the from zone, right?
2. Is there any way to change the To and From positions of the zone?
Solved! Go to Solution.
‎2022-07-20 07:15 PM
- You will need to create a custom property for ddoors /Windows with expression "if" statement. For example "if" the room name is "foo" then you get "To" else you get "From"
- instead of name of room as a condition you can create a second custom property as True or False. when the value is True, the custom property "To" and "From" that you create will be flipped.
‎2022-07-20 07:47 PM
there is also another way to do that with pictures. have a look at this post
https://community.Graphisoft.com/t5/Document-articles/Scheduling-Doors-by-Zone/ta-p/303883
‎2022-07-20 08:24 PM
means the door didn't recognize the Zone.
check that the Zone is Automatic and reload it. If it is manual then the edges of the Zone must include the door.
‎2022-07-20 07:27 PM
Can you show me an image?
I speak short English. ^^
‎2022-07-20 07:57 PM
thank you ^^
This is what I was looking for. ^^
‎2022-07-20 08:05 PM - edited ‎2022-07-20 08:09 PM
May I ask about this here too?
What should I do if the entrance does not appear in both?
Yellow color is zone
‎2022-07-21 03:17 AM
Thank you so much
I think I need to study this part more.
The wall is made in the shape of our country.
The connection between the wall with the door and the zone seems to be a problem because it seems to be up to the reference line.
Guess I'll have to re-model it... ^^
Thank you for your interest.
‎2022-07-21 03:26 AM - edited ‎2022-07-21 03:29 AM
A door will only come out if the zone area contains a wall.
End of test ^^
