LeeJaeYoung
Is there any way to change the To and From positions of the zone?
1. Only 침실3 (room 3) appears in the from zone, right?
2. Is there any way to change the To and From positions of the zone?
AC27 on window 11
3 Solutions
Ady84a
- You will need to create a custom property for ddoors /Windows with expression "if" statement. For example "if" the room name is "foo" then you get "To" else you get "From"
- instead of name of room as a condition you can create a second custom property as True or False. when the value is True, the custom property  "To" and "From" that you create will be flipped.
Go to post
Ady84a
there is also another way to do that with pictures. have a look at this post
https://community.Graphisoft.com/t5/Document-articles/Scheduling-Doors-by-Zone/ta-p/303883
Go to post
Ady84a
means the door didn't recognize the Zone.
check that the Zone is Automatic and reload it. If it is manual then the edges of the Zone must include the door.
Go to post
8 Replies 8
Ady84a
LeeJaeYoung
Can you show me an image?
I speak short English. ^^
AC27 on window 11
Ady84a
LeeJaeYoung
thank you ^^
This is what I was looking for. ^^
AC27 on window 11
LeeJaeYoung
May I ask about this here too?
What should I do if the entrance does not appear in both?
Yellow color is zone
AC27 on window 11
Ady84a
LeeJaeYoung
Thank you so much
I think I need to study this part more.
The wall is made in the shape of our country.
The connection between the wall with the door and the zone seems to be a problem because it seems to be up to the reference line.
Guess I'll have to re-model it... ^^
Thank you for your interest.
AC27 on window 11
LeeJaeYoung
A door will only come out if the zone area contains a wall.
End of test ^^
AC27 on window 11
