Sally2720
Issues with the Window Schedule's Annotations being offset or incorrect
The annotations inside the window elevation viewport is showing the annotation text and arrow offset (image 01), but within the actual annotation space, it is correct (image 02). Has anyone had this issue? i have tried everything to fix this annotation offset, but the preview window always shows it offset.
2 Replies 2
Is the text in the wrong position if you place it on a Layouts? On a published PDF?
CosminF
It seems like a scaling issue to me or an anchor point issue since the arrow is correct, only the text is misplaced.
Can you set the text anchor point to Right?
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
