Project data & BIM
Morph listing parameters issues
Cardiac
Hope you are good community
I just wanted to know how to classify morphs as beams so that I can schedule them for height width and length because It looks like the morphs do not have this option for listing heights and lengths.
Thanks and I will be grateful.
7 REPLIES 7
Cardiac
Barry sorry for interference
How do I classify a morph into a beam so that I can schedule it for length width and height
Thanks man
Ricardo Lopez
Hi @Cardiac
Because of the main purpose of Morph tool is modeling whatever in a free way, it can be difficult to determine its individual dimensions. But there could be a quite painful workaround using Classifications (Ex: beam, column, object, etc.) and create custom Properties (Ex: morph_width, morph_lenght, morph_height, etc.) so you could manually populate them to be included in a schedule.
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
You can classify a morph as a beam, but it will still not have a length and width.
Ricardo has suggested you can add properties for these, which you can.
You will also have to fill in the value of these properties manually for every morph and amend them if you modify the morph.
They will not list in a schedule as the same length and width fields as an actual beam, you will have to add the length and width properties of the morphs as fields as well.
So the beams and morphs will still list separately.
Why do you need a morph as a beam?
Why not just use an actual beam?
Thanks Barry
I need a morph as a beam or column because
For example I need to do the slanted legs of the certain stool with chamfered edges. First will use the slanted column then I convert the column to morphs so that I can chamfer the edges of that column
So when I convert that column to morphs I loose the listing parameters like lengths and width of that column I changed into a morph. So to get these parameters may be I should classify that morph into a column again.
I wanted to know this because I can use those parameters to determine the number of timber used for that leg of a stool
Thank you sir for your explanations I appreciate 🙏🙏🙏
You can classify a morph as a beam or a column, but it will never be a beam or column, it is still a morph.
You can use a complex profile for the column.
This will allow you to chamfer fillet the corners.
Unfortunately you will see lines for the chamfer fillet and at small sizes the radius will be very segmented.
Edit: with a chamfer you will want to see the edge lines.
With a fillet you won't see nice round curves and you will see the edges of the curves as they blend into the straight surface (which you probably don't want).
Hi @Cardiac
As @Barry Kelly said, you can create a complex profile and schedule its dimensions. Just a tip for slanted columns: use 3D Length instead of Heigth. See example below.
Regards
