Project data & BIM
Origin of cover fill of a component of composite structure?
For a project we are working on, I have created a series of composite structures, all of which have the same finish, tile below and painted wallboard above - each has a different substrate/framing/insulation condition, but the finish layer is consistent amongst all composite structures.
We have created a material (vectorial hatch) for the "Side material" of the lower part of Finish Component of the structure: QUESTION: Is it possible to set or edit the origin of a Composite Structure compnent "Side Material", as you can with a cover fill - "Link to Origin"?
You can probably get a sense of the problem we need to solve from the screenshot.
Thanks for any help
You can select the wall in 3D view and use the DESIGN > ALIGN 3D TEXTURE commands.
But this will move all of the fill patterns on the face of the wall.
In your case this should be fine as the tiles are a fill pattern but the painted wall above has no fill.
I don't know of a way to align the individual fills in a composite wall.
Thank you Barry, let's me do exactly what I hoped to do.
Paul
