Project data & BIM
Roof slope label
I created a roof slope label with autotext using:
CONCAT ( STR ( TAN ( PITCH ) * 12, 0 ), "/12 - PITCH" )
which works except that for a low slope roof it will not show the fraction, IE 1/2"/12" is shown as 0"/12"
7 REPLIES 7
Peter Baksa
This looks like a property expression, which is not GDL, but I guess it is rounding down to 0. I don't know if a property expression can be used to format a number as a dimension, probably not.
In GDL you can use STR{2} to format numbers as dimensions. REQUEST ("Linear_dimension" ...) can be used to get the format string that the user set in the work environment.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
DGSketcher
Legend
If you assign the roof pitch using Autotext (#Pitch) in a label does it not display in your required units?
I'm in metric so it may be a regional unit problem.
Peter Baksa
I played around with it and got a solution.
There is an STRCALCUNIT function that formats a length with the work environment calculation units.
The result of TAN has to be converted from a number to a length: 1 ft * TAN( {Property:Roof/Pitch} )
STRCALCUNIT ( 1 ft * TAN ( {Property:Roof/Pitch} ) ) will give the number you need.
CONCAT ( STRCALCUNIT ( 1 ft * TAN ( {Property:Roof/Pitch} ) ); "/12\"" ) is the concatenated expression, \" is needed to write an " inside a string. It renders a different character on the UI, but works.
Péter Baksa
This is giving me a Syntax Error. When I jump to the last  valid character, it's right after CONCAT
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
I'm having similar syntax error as reidweber.   Hoping to open the thread again to find a solution.  Rather than /12 I would like to put /1'-0" at the end of the expression.  Would that be .... /1\'\-\0\"")
ArchiCAD v28 (since v11)
MacBook Pro M1 Max, 64GB
macOS Sequioa
cmb
The error at CONCAT is your local language setting of your system. You need to put a comma in the list of elements being operated on by the CONCAT. The person posting CONCAT ( STRCALCUNIT ( 1 ft * TAN ( {Property:Roof/Pitch} ) ); "/12\"" ) is somewhere where they use a semicolon.
cmb
Here's an expression that will yield a label that looks like 3/4"/12". One issue that comes up if you have calculation units set to feet and inches is that the label will throw up a value like 0'-3/4", which isn't kosher.
The 0'- gets replaced with a null ("").
REPLACE ( CONCAT ( STRCALCUNIT ( 12 in * TAN ( {Property:Roof/Pitch} ) ), "/12\"" ), 1, 3, "" )
