Project data & BIM
Schedule - Select of Floor Plan
insideru
If I remember correctly, in AC19, selecting a ... door let's say, in a schedule, that has instances in multiple stories, then pushing Select in Floor Plan, used to Select all the doors (in this case) in the floor plan that was open in the main tab.
In AC20 (even on b6005 preview), no matter my current story, if i push Select on Floor Plan it switches my main tab to the lowest story that has an instance of that door.
Is this intended, is there a way to revert back to the old behavior?
ARCHICAD 28 INT
macOS Sequoia
0 REPLIES 0
