Project data & BIM
Scheduling 2D and 3D Properties
gdford
There seems to be a default shading for the 3D view of objects in a schedule.
Nothing in surfaces or 3D view options styles and sunlight will get the shading lighter.
With surfaces I can make the shading darker, but I can not get it lighter.
Is this really hardwired or am I missing something?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
4 REPLIES 4
Botonis
Mentor
I dont know if overrides will do the job when you save a view. I am not at my pc. Cant remember if overrides work for scheduled.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
Rubia Torres
Hi @gdford, does the issue occur only with this object from the screenshot?
If yes, can you please send it over for a check?
Meanwhile, Graphic Overrides may be enough to achieve the desired result. Please check this thread on the topic and try it out.
Best,
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
Erwin Edel
You can use graphic overrides to make them completely 'black and white' (no fills, just lines). This is what we do with our door/window schedules.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks everyone for the suggestions - I will run some tests and then let you know.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
