‎2022-12-28 09:47 PM
There seems to be a default shading for the 3D view of objects in a schedule.
Nothing in surfaces or 3D view options styles and sunlight will get the shading lighter.
With surfaces I can make the shading darker, but I can not get it lighter.
Is this really hardwired or am I missing something?
‎2022-12-28 10:36 PM - edited ‎2022-12-28 10:37 PM
I dont know if overrides will do the job when you save a view. I am not at my pc. Cant remember if overrides work for scheduled.
‎2023-01-04 01:27 PM - edited ‎2023-01-04 01:45 PM
Hi @gdford, does the issue occur only with this object from the screenshot?
If yes, can you please send it over for a check?
Meanwhile, Graphic Overrides may be enough to achieve the desired result. Please check this thread on the topic and try it out.
Best,
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
‎2023-01-04 03:49 PM
You can use graphic overrides to make them completely 'black and white' (no fills, just lines). This is what we do with our door/window schedules.
‎2023-01-04 03:56 PM
Thanks everyone for the suggestions - I will run some tests and then let you know.
