Gerry Leonor
Surface with different vectorial hatchings
not sure if this has been asked before, but i was wondering if there was a way to set up one Surface (say a paint colour, Dulux Vivid White) with multiple vectorial hatchings. If i use that one colour on a concrete tilt panel, i'd like to associate the "Render" fill for it's vectorial hatching. if i used the same colour on an external fibre cement sheet, i'd like to not have a vectorial hatch, or use the "Empty Fill" fill type.
is there a way to set this up? or do i have to have multiple Surfaces with the same paint colour just to have different vectorial hatchings?
Is there a way around this? i hate to use a 2D fill just to make this look decent. i don't want to go back to the pre-vectorial hatching days of manually editing fills (or at least knowing the existence of such a tool). -shudders-
thanks.
https://discord.gg/XGHjyvutt8
5 Replies 5
alemanda
Just duplicate the surface and assign a different vectorial hatch
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Gerry Leonor
thanks. i've done that before. but i wanted to ask if anybody else has found another way of doing it & have avoided a large list of duplicate surfaces with small differences.
Erwin Edel
You could 'model' the panels by substracting small gaps from it, but that seems even more time consuming.
We work with the multiple surfaces as well. Sometimes even duplicates of the same excact same surface to stop elements from 'melting together' in views where we want a separator line to show.
The list is still quite manageable though. We have a pretty bare needs template, with the library of cinerender materials available to import any specific needs.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Unfortunately there is no other way to solve this than by duplicating Surfaces.
This is because the Vectorial Fill applied is a parameter of the Surface definition. So you need to create a Surface definition with a Vectorial Fill applied and one without it applied.
Erwin Edel
I did submit a wish for a way to transfer individual sub-settings from surfaces to our local reseller that sort of ties into this. With cinerender you can have such intricate detailed settings for so many parameters it is a pain to replicate for example the reflection settings of one material onto another (say you want the same gloss effect on a painted and blank lacquer surface, or just on a wood boarding and painted surface).
www.leloup.nl
