Just so you know Tom, when signing in the usual Marquee Selection Methods (Single Floor, All Floors) have no effect.
So when you sign in with the marquee, you need to also specify which stories you want to sign in to, by selecting them under the Stories panel.
You can only sign into one marquee per teammate, which will be the same across any stories you selected above.
If someone else signs in with a marquee, they will have all the layers available to them, as long as the marquee doesn enter the worskpace of anyone else.
That's it in a nutshell. Does it answer your question?
Link.
