2011-09-01 09:28 AM - last edited on 2023-05-30 12:43 PM by Rubia Torres
2011-09-01 10:09 AM
2011-09-01 10:13 AM
2011-09-01 10:14 AM
2011-09-01 11:30 PM
2011-09-02 01:26 AM
zeropointreference wrote:This is not necessary. Do not do it this way unless you are sure there is some compelling reason to do so (usually for export to something that doesn't have stories).
Instead you will have to create separate layers to divide up the floors (ie only first floor objects go into the first floor object layer and so on) and separate layer combos to achieve what you want.
2011-09-02 01:36 PM
2011-09-05 10:35 AM
zeropointreference wrote:By 3D model are you referring to a 3D view (like a perspective) or the entire model?
Or is it possible to setup a 3D model with different layer settings for each floor at the same time?
2011-09-05 11:49 AM
uisanata wrote:zeropointreference wrote:By 3D model are you referring to a 3D view (like a perspective) or the entire model?
Actually it is possible for both! And it is possible to have different layer settings for the same floor at the same time!
2011-09-05 12:11 PM
