Project data & BIM
Turning off layers in one LEVEL and not on the others
I have a building with 3 levels.
i really want to have certain LAYERS turned on in 2 and turned off in the other.
It seems when i turn off a LAYER, it turns off in every layer and even my Perspective View.
any help would be super.
Thank you.
Ian
22 REPLIES 22
As far as I know you cannot display layers like that. Instead you will have to create separate layers to divide up the floors (ie only first floor objects go into the first floor object layer and so on) and separate layer combos to achieve what you want.
In plan views, this is fairly straight forward - save view of each floor with the specific layers turned off or on as required.
In any 3d, including elevations, sections, 3d document etc, the easiest way is probably to set up a separate layer for specific items on each layer that you can turn on or off as required (e.g. WALLS_level 1, WALLS_level 2, WALLS_level 3 etc.)
If you don't mind seeing the outline only, you can always create a new material with full transparency to assign to elements you want to see through.
owen
Yes thats how Layers work .. they are global.
You need to use Layer Combinations with saved Views to control the visibility on different levels, possibly also introducing additional layers to give you more control over specific elements (e.g you could have 'Beam Steel' and 'Beam Steel 3D' layers to separate elements you want to see in plan views from those only seen in Sections/Elevations/3D)
cheers,
owen
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Ernest Atanasiu
STOP using the Project Map for Construction Documentation!
It's purpose is MODELLING!
To answer your question: In View Map use Layer Combinations.
For layer Combination 1 use whatever layers you need, for layer Combination 2 use other layers, and so on...
and
Don't use additional layers that have the same elements! (like owen said). MODEL AS BUILT! Imagine having to extract a quantity list from a model that contains 3 or more beams in 3 or more layers...
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
This is not necessary. Do not do it this way unless you are sure there is some compelling reason to do so (usually for export to something that doesn't have stories).
As others have pointed out, use views for different drawings and layer combos.
The way I was reading his question was he was partially asking how to display the 3D model while showing a layer on story 2 but having that layer off for the other two floors (when he mentions perspective).
I thought turning on or off a layer in 3D view affects all floors and which is why I suggest that you have to put stuff on separate layers if you want this kind of display.
Or is it possible to setup a 3D model with different layer settings for each floor at the same time?
Or maybe I just read everything completely wrong and it's just a simple matter of setting up views for the different floors and navigating that way instead of constantly setting layers so the current display is correct.
Ernest Atanasiu
By 3D model are you referring to a 3D view (like a perspective) or the entire model?
Actually it is possible for both! And it is possible to have different layer settings for the same floor at the same time!
If you know the answer, why not elaborate?
Ernest Atanasiu
http://www.youtube.com/watch?v=kb_YYU3O_Ow
There was a better tutorial by Eric Bobrow, but I can't find it right now.
