on 2019-11-26 04:00 PM - edited on 2023-05-15 05:23 PM by Emoke Csikos
1. Go to Options > Property Manager... to open the Property Manager dialogue box.
2. Click the New button to the New Property / Group dialogue box.
3. In the New Property / Group dialogue box, select Group, enter the Group Name and click OK.
4. Click the New button to open the New Property / Group dialogue box.
5. In the New Property / Group dialogue box, select Property, enter "Occupancy Type" for Property Name, set Add to Group to the group that was just created and click OK.
6. Select the Occupancy Type property and under the Value Definition tab make sure that Data Type is set to Option Set and Default Value is set to Value. Once Value is selected, the Options Setup dialogue will automatically open. This dialogue box can also be accessed by clicking the Options Setup... button.
7. Click the Add button to create a list of occupancy types. The name should include a descriptor (ex. Library), followed by a separating character (ex. | or /), followed by the area required in the space per person. Once all values have been created, click OK.
8. Back in the Property Manager dialogue box, click the New button to open the New Property / Group dialogue box.
9. In the New Property / Group dialogue box, select Property, enter "Occupant Load" for Property Name, set Add to Group to the same group as in previous steps and click OK.
10. Select the newly created Occupancy Load property and under the Value Definition tab make sure that Data Type is set to Integer and Default Value is set to Expression. Once Expression is selected, the Expression Editor dialogue will automatically open. This dialogue box can also be accessed by clicking the Add... button.
11. In the Expression Editor dialogue box, click the Operators & Functions button.
12. In the pull down menu, under Data conversion, select Number from string [ STRTONUM ] and click Add.
13. Select "Text" (including the quotation marks) and click the Operators & Functions button.
14. In the pull down menu, under Text editing, select Split string to right [ SPLITRIGHT ] and click Add.
15. Select "Text" (including the quotation marks) and click the Parameters & Properties... button.
16. In the pulldown menu, under the Properties > Zones tab, select Occupancy Type and click Add.
17. Select and delete Delimiter (DO NOT include the quotation marks) and enter the trimming character and the space that follows it "| ".
18. Select and delete PartIndex, enter "2" and click OK.
19. Back in the Property Manager dialogue box, click the New button to open the New Property / Group dialogue box.
20. In the New Property / Group dialogue box, select Property, enter "Occupants" for Property Name, set Add to Group to the same group as in previous steps and click OK.
21. Select the newly created Occupants property and under the Value Definition tab make sure that Data Type is set to Integer and Default Value is set to Expression. Once Expression is selected, the Expression Editor dialogue will automatically open. This dialogue box can also be accessed by clicking the Add... button.
22. In the Expression Editor dialogue box, click the Operators & Functions button.
23. In the pull down menu, under Mathematical functions, select Round up [ ROUNDUP ] and click Add.
24. Select Number and click the Parameters & Properties... button.
25. In the pulldown menu, under the Zone tab, select Measured Area and click Add.
26. Add a space after "Measured Area" and click the Operators & Functions button.
27. In the pull down menu, under Operators, select Divide [ / ] and click Add.
28. Enter the number 1 after the division sign but before the comma and click the Units button.
29. In the pull down menu, under Area, select Square feet [ ft2 ] and click Add.
30. Add parentheses before "Measured Area" and after "1 ft2" and add a space after the second. Click the Operators & Functions button.
31. In the pull down menu, under Operators, select Divide [ / ] and click Add.
32. Add a space after the division sign but before the comma and click the Parameters & Properties... button.
33. In the pulldown menu, under the Properties > Zones tab, select Occupancy Load and click Add.
34. Select and delete NumberOfDigits, enter the number 0 and click OK.
35. Select the 3 newly created properties, under the Availability for Classifications tab select Custom and click Edit...
36. In the Availability dialogue box select Space and click OK.
37. Click OK in the Property Manager dialogue box to exit.
1. Open the floor plan.
2. Select a zone and open the Zone Selection Settings dialogue box.
3. Under Classifications and Properties, navigate to the Classifications section. Make sure that the classification is set to the one associated with the expression properties created earlier.
4.Under the Zones section, set the Occupancy Type for the selected zone.
5. Under the Settings tab, navigate to the Content section and click the + button.
6. Click on the new field entitled "** Empty Row" and choose Measured Area. Click the + button to add another field.
7. Click on the new field entitled "** Empty Row" and choose Classification and Properties.
8. Under the Settings tab, navigate to the Classifications and Properties. Set the Select Data field to Create Sorting. Set the Display Data by field to Parameter Name and Value. Select row 1 and click the arrow.
9. Select the Occupants property and click OK.
10. The maximum number of occupants will now appear in the zone stamp.
11. Repeat the process for other zones in the project.
perhaps the Option set could be created from the Zone Categories in the future
Interesting!
I will check it out compared to the requirements of some local building codes.
We can get a total but how to add some text (or create a unit) to the total so its clear what the total refers to.
For example 47 occupants. (the schedule area says 141.93 m2 but the occupants have no units)
It seems to me that the whole issue with Expressions is that we can't create new units. This wasn't the case with the "OLD" Properties. Perhaps I have missed something.
@David Shorter I am not sure the number of occupants needs to be expressed in some units. To calculate occupancy load, we can directly refer to our respective local building code(s) to check it out compared to that of the Archicad zone properties.
@Martin Jules There are a number of reasons why totals need to be expressed with specific units and this should be a basic function.
Here are two examples.
The above is a Farm plan with a layout of the paddocks.
The paddock areas are measured in hectares and are scheduled as such
BUT its impossible to show the total in Ha
Here is another example where I cant show the total as bricks
or define the total as blocks
Its really silly to have export the schedules to Excel just to define the 'units'
I agree it would be nice to have the units in the totals, but you heading does say what that column is.
@Barry Kelly With a long schedule you may not see the top and why then be able to put M2 or m3 against the total and not the more obscure units. With the OLD properties this easy as units were applied at the end of the calculation just like Excel.
You can freeze the header in 25.
I'm not sure how many versions back that can be done or if it is just new in 25.
This is only on-screen in Archicad.
In the layouts you can split the schedules across multiple pages and i am pretty sure that duplicates the headers.
@Barry Kelly OK but its a workaround for something which should be accessible by default.
Unfortunately with the complications of having to specify and use units during the calculation I suspect it almost impossible.
@David Shorter I will check it out again this week-end and will let you know.
