2015-11-30
05:55 PM
2023-05-30
12:39 PM
Rubia Torres
2015-11-30 07:47 PM
2015-11-30 08:34 PM
rob2218 wrote:Yes, because that is the current state of the model the Section marker is cutting thru'. If you want the correct MVO and layer combo just use the Navigator View Map. Its just a double click.
…it opens with the RCP layer combo as well as opening with the RCP model view options...
2015-11-30 08:43 PM
laszlonagy wrote:
A linked Marker can be linked to a Viewpoint but not a View. Which means that when you open the linked Viewpoint using the Marker, the Viewpoint will be activated, but all settings for Layers, Scale, MVO, etc. will stay the same. This is how switching from one Viewpoint to another works.
Only when you switch to or activate a View (which is a captured state of a Viewpoint) will ARCHICAD restore the Layers, Scale, MVO, etc. settings that is stored in the View.
So this command doesn't activate a View, it activates a Viewpoint and this is why it works the way it does.
You could make a wish: ability to link Markers also to Views, not only to Viewpoints (and Drawings placed on Layouts). If such a wish was implemented it would be possible to achieve what you want.
2015-11-30 08:48 PM
s2art wrote:
Hey Bobby Hollywood, it's really hard to grab a quote from your thread when you type all the text in your image.![]()
2015-11-30 09:30 PM
2015-11-30 09:35 PM
2015-12-01 02:13 AM
laszlonagy wrote:
I think ARCHICAD 19 solves your case with the TABs. You open all the various TABs you wish to use and you can very easily switch from one to the other. A TAB can display a Viewpoint or a View, as needed.
So you can have a Floor Plan View in one TAB and a Section View in another, both with their own settings and it is very easy to switch back and forth between them.
2015-12-01 01:46 PM
2015-12-02 05:13 AM
rob2218 wrote:Install it! As long as you have enough room on your hard drive it will probably not make any difference in how fast ArchiCAD runs.
thanks.
I have yet to install AC19. I'm worried it'll bring my laptop to grinding hault.
Eventhough my laptop is 4 years old I had ordered it from Dell with all the 'bells-n-whistles' to be a desktop replacment.
I-7 processors.
lots of RAM
lots of HD space.
etc....
but I have yet to install AC19.
