mukster
WINDOW SCHEDULE
Having a problem with my window schedule. Cannot get anything to show up. Changed the walls from new to existing and nothing shows up.
13 Replies 13
Your door schedule is clearly working.
What are the criteria for your window schedule?
How does it differ from the door schedule?
Could you post a screenshot of your Scheme Setup Dialog that shows the criteria used for the schedule?
Ricardo Lopez
Hi @mukster
When saving a view with the schedule, you must select the renovation filter to display the desired items.
You can check your criteria in the scheme settings, as the renovation status can also be used for filtering.
Regards,
Ricardo López, M. Arch.
mukster
Partially works. Does not show the first floor windows, only the second
Ricardo Lopez
Hi @mukster
Maybe the walls have their correct renovation status applyed but windows have their own. I mean, you can have an existing wall with an existing, demolished or new window on it.
To check this, try creating a 3D view with the same view settings in which you isolate the walls and their windows with a filter and verify the different renovation statuses to ensure that everything appears correctly. If so, there should be no problem with the window schedule if the criteria is applied correctly, as I mentioned in my previous message.
mukster
The window is new, the wall is new
You need to show us your schedule criteria settings.
Otherwise we are just guessing blindly.
mukster
Ricardo Lopez
Hi @mukster
Could you share the view settings of the schedule too? There should be a Renovation filter option to check.
