2005-08-02
08:12 AM
- last edited on
2023-05-30
01:03 PM
by
Rubia Torres
2005-08-02 08:14 AM
2005-08-02 09:01 AM
2005-08-02 09:18 AM
2005-08-02 09:43 AM
andthen01 wrote:
Why would you set the priority such that a hidden layer's wall interferes with a visible layer's walls?
2005-08-03 04:18 AM
Fmr wrote:very well put! i agree that the usefulness of the priority-based layers system far outweighs the little 'quirks' that you find from time to time.
For me it is a good function with "little" disagreements…
Intersections wrote:2. when you
As a result of this ArchiCAD Add-On, layer combinations will emulate the visibility-based intersection cleanup logic of earlier ArchiCAD versions.
In ArchiCAD 8 and subsequent versions, intersection cleanup is linked to the Intersection Group Numbers assigned to layers. If the layers of visible elements have different Intersection Group Numbers, the connections of these elements will be not cleaned up.
With this Add-On, you can automatically assign a Group Number of 1 to all visible layers and a Group Number of 0 to all invisible layers registered in Layer Combinations. From then on, activating a Layer Combination will always deliver clean elements intersections. Layer combinations of old projects can then be used as before.
Important: Any Intersection Group Numbers you have already set up in this project will be overwritten.
2005-08-04 01:41 AM
2005-08-04 04:50 AM
Bruce wrote:
Where does one find this useful-sounding add-on?
I wrote:
it can be found in the 'goodies' folder and loaded, as usual, with add-on manager.
2005-08-04 10:57 PM
