2007-12-13
01:47 AM
2023-05-26
03:55 PM
Rubia Torres
2007-12-13 05:59 AM
2007-12-13 11:30 AM
Michael wrote:I know of one way that can cause this (there might be others): Fills can be defined in GDL. If you loaded a library that contains a GDL file which has Fill definition commands in it (this is usually a GDL file starting with the string "MASTER...") then no matter how many times you delete those fills, every time you reload the Library, those MASTER GDL files are executed and any Fills defined in them will be recreated. Maybe it comes from an Add-On Library or Third party Library. If you unload those MASTER GDL files from the Library, they will not recreate those Fills.
I'm trying to delete my unused Fills, but they automatically reappear in my Fills list.
I've spent hours carefully deleting the useless and the repeats, and got my list down to about 100 Fills (which I renamed), using both Attribute Manager and the Fill Type dialogue.
But low and behold, the 75 or so banished Fills just keep coming back, quite magically I might add....
Any thoughts anyone? Thanks in advance.
2007-12-13 05:57 PM
2007-12-13 08:23 PM
