detail library
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-07-13 10:06 AM
‎2010-07-13
10:06 AM
I am just setting up archicad in the office. What is the best way to go about setting up a detail library. Just standard eaves etc. I would like to be able to use them as "detail templates" while I rebuild the library, and store them separately to the projects I am working on. I am wondering if anyone has some 'best practice' tips. I sure don't want to draw them all twice.
Cheers Jo
Labels:
- Labels:
BIM Management
27 REPLIES 27
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-19 01:34 PM
‎2010-07-19
01:34 PM
Kristian wrote:I guess the Section thing comes from an earlier version of ArchiCAD.
Each detail has its own section so that the scale can be set independently.
Then each of those sections are setup in the view map, making it easier to index and find the details.
Nowadays it is best to use the independent Worksheet viewpoints for this purpose instead of Section viewpoints.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-19 03:08 PM
‎2010-07-19
03:08 PM
To continue the Western Australian theme
(the finest users of ArchiCAD since 4.5)
this is what we do.
1. have a dedicated .pln with every detail in a detail view at different scales
2. Each detail is saved as a view
3. We have a publisher set - exporting the views as .mod files to a place on the server. MOD files will show in the windows navigator like the .dwg's in Laszlo's screen shot with out anything else installed!!
4. The details are then selected graphically and dragged and dropped into ArchiCAD.
Easy to setup and maintain. Easy to use. (very similar to using Autosketch blocks). You can also create modules for other things. For example, standard carports, complete with roof, ceiling, piers, dimensions, notes... everything - just drag and drop the .mod file onto your ArchiCAD file. Its very handy.
Hope this helps.
this is what we do.
Hope this helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-19 05:19 PM
‎2010-07-19
05:19 PM
Here's a good discussion by Eric Bobrow: Detail catalog
Richard
AC26 (since AC6.0), Win10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-20 12:17 AM
‎2010-07-20
12:17 AM
Both Ben's and Eric's ways highlight the over worked way of doing something simple
How I would like it is having your external Library of .mods in a folder structure. When importing them into your project, AC AUTOMATICLY sets up a detail view with the same name,scale in the project. Then you just drag into Layout. Pure and simple.
Also this way you can tweak that detail for that project and it does not effect any other project. You can then save these tweaks out to your Library if you need them again.
And as I said earlier, for Details that don't need changing in the project, being able to place .mods as drawings straight into the Layout would again be simple.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-20 09:43 AM
‎2010-07-20
09:43 AM
If you want to place standard, unaltered, details on layouts: just publish them as .PMK and place those on the layout.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-27 12:25 AM
‎2010-07-27
12:25 AM
FWIW
I used to create independent details (tools>independent detail) and they were an integral part of the template and always in the details list ready to be used when needed. No external files, dwgs. modules etc. Millwork profiles, fireplace details and even standard notes were already in the plan when it was opened for the first and the file size was negligible. The template I used for the occasional homeowner/builder who just wanted something to get their permits with and was going to do whatever they wanted anyway had the entire IRC (2003) in it and I could drop the pertinent section on the sheets.
Independent details have a different icon in the navigator list and if you name them properly the placed details will be added to the top of the list so you don't have to browse through everything to find the project specific or linked details although you can also link a detail marker to them when needed. You can always delete the ones you don't need for a particular project but I never bothered.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-11-29 11:00 PM
‎2010-11-29
11:00 PM
Brett wrote:Brett, I didn't quite get your meaning. Is this a wish? Or is it already possible to do these things that you mention?
When I import (merge / drag & drop) mod files, it doesn't create any view at all. Also, when I drag the mod file into layout, it comes in as a group of 2d elements, not as a drawing - thus not showing detail name, scale, etc.
It would be quite nice if what you said is possible.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Windows 10 x64
Since ArchiCAD 9
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-11-29 11:15 PM
‎2010-11-29
11:15 PM
Ben wrote:Ben, when you drag and drop your mod files into ArchiCAD, do you create an independent detail prior to drag and drop? Do you drag and drop into the layout? If so, how do you do the detail title?
To continue the Western Australian theme(the finest users of ArchiCAD since 4.5)
this is what we do.
Hope this helps.
Windows 10 x64
Since ArchiCAD 9
Windows 10 x64
Since ArchiCAD 9
- « Previous
- Next »
- « Previous
- Next »
