2006-01-31
09:44 PM
- last edited on
2023-05-26
09:05 AM
by
Rubia Torres
2006-01-31 10:08 PM
2006-01-31 10:44 PM
2006-01-31 11:25 PM
2006-02-01 12:02 AM
2006-02-01 04:01 AM
Hassanen wrote:I had this problem for the first time a couple of weeks ago. The same hotlinked pln stories were being fed to two different but substantially similar site files (and updated fairly simultaneously, etc.). On one of the files I kept having the moving hotlink problem. The source files were obviously OK, no inadvertent dragging the building around there, otherwise I would have had the problem on both files. And it wasn't a problem of sloppy drafting on the destination file either, because just as you describe the things moved a couple of times when updating.
there must be a serious bug here, I now linked to two different PLN files. locating them in the right place, after I update all hotlinks, each one of the two linked files moves to a different location!
2006-02-01 04:09 AM
