Project data & BIM
show zones in section - intersection with cutted elements
bimdo
Hello togehter
Is there a way to change the priority for the intersection of zones & other elements in the section?
What we want to do:
- Drawing one big Morph over the hole project.
- Drawing the zones with a white background.
- In the floor plan we get now "normal" floor plans, which are looking like there were walls, but actually there's a morph in the background and a zone in the front.
- In the section we get the problem, that the zones only are visible (the contour line is visible, but the fill not) when we hide the morph-element.
Workaround: Hide the morph and do two different drawings which are layouted both on the same paper. Any other "better" solutions to solve this?
Reason why we're doing that: We need in the early project phases only an ifc with zones and with this workflow our architects in the office are much faster. The goals is to get a correct zone model instead of a complicate wall/ slab model which is not correct. Afterwards we threw the zone-model into the platform abstractbim and get a structured ifc for cost-simulations.
Archicad 27 / Archicad 28 INT/ CHE/ FRA
Windows 11
0 REPLIES 0
