‎2019-03-15 06:29 PM
Solved! Go to Solution.
‎2019-03-18 08:46 AM
‎2019-03-18 09:57 AM
‎2019-03-18 11:40 AM
Barry wrote:Would this happen if you save the module file from the originally hotlinked PLN though? I would assume the internal ID would stay the same. Still, fair warning, that might happen.
If you are re-linking your hotlinks, then you may lose any associated dimensions if you have added any to your main file.
‎2019-03-18 12:09 PM
Barry wrote:Ouch. No go then. Dot't dare to chance. We'll do the .mod next project.
‎2019-03-19 01:51 AM
‎2019-03-19 02:54 PM
Barry wrote:It sounds very logical
The only way you will know for sure is to try it and see.
You don't have to save your main file if it doesn't work.
Or try it on a small test file.
I have not tried it but I am assuming because you are replacing one hotlink with another and that they could be totally different, there is no way that associated dimensions could stay.
Even if the MOD file is based from the original PLN that was hotlinked so they are essentially the same, I am guessing that associated dims will be lost.
‎2019-04-17 02:43 PM
‎2019-05-03 07:47 PM
kzaremba wrote:Next project: the way around that is to place room-equipment-etc. dimensions in the module and only overall dimensions in the main file (just as you are doing), but when those overall dimensions refer to a module or hotlinked pln element associate them instead to an ad hoc local shocking pink hotspot —which will not disappear when things change in the module or the module itself changes, and you can still move around without losing dimensions strings when things move around.
It is always tricky to handle dimensioning out of hotlinks. We usually put as much dimensioning in hotlinks. And limit dimensioning is the main file since they just vanish from time to time when you reload hotlinks.
‎2019-05-03 10:35 PM
another Moderator
