2019-03-15 06:29 PM
Solved! Go to Solution.
2019-05-13 11:59 AM
ejrolon wrote:Very interesting thought. Are you sure that dimensions are becoming static when they miss point form hotlink? I did some quick test but this prop is not available for selection tool.
Also, you can try using GOs with a rule for Dims=Static to highlight that the dimension was not to the "pink" spot.
Ignacio wrote:By pink spot, you mean Hotspot (Active Point) tool? This approach is ok but you still have to manage changes in dimensioning. Which is in some cases harder to spot than the whole chunk of dimensions.
c local shocking pink hotspot —which will not disappear when things change
2019-05-13 12:59 PM
another Moderator
2019-05-13 01:51 PM
ejrolon wrote:Thanks. I will do some testing. This might be a way to identify those that are modified during an update.
IIRC on a update the dimension can become static.
2019-05-13 02:01 PM
kzaremba wrote:If overall dimensions don't change, there is no need to manually update that necessarily 'static' (unlinked to module) dimension point even if the module element changes or the hotlink gets redirected. And there is no way out of having to manually manage that dimension point if you want it to allow that hotlink to get redirected or that overall dimension to change, so the question is how to best manage that situation.
2019-05-14 02:37 PM
2019-05-15 02:08 PM
kzaremba wrote:The advantage of the hotspot is that it very visibly tells you which one is the traditionally-untraceably-static-now-associated-to-hotspot-instead dimension point, and reminds you that dimension point should tie to it and not to the module element. This is a very traditional procedure, used also say for top of wall level dimensions in sections and wall sections where you don't want your dimensions to disappear whenever a wall element gets replaced or a module redirected, stair section dimensions where you know your landing levels but will keep on changing the model elements, etc.
I really don't see the benefit of the hotspot. I'd rather double check dimensions when 2d drawings are about to be published. Since possibilities of editing Dimensions improved you can skip hotspot's imo.
2019-05-15 04:56 PM
