2010-09-04 10:30 PM - last edited a week ago by Aruzhan Ilaikova
2010-09-24 05:18 AM
2010-10-14 11:19 PM
qwsoftdraw wrote:I have seen this exact error message, and it seems to be caused by virus scanning software, what's more, another message I've seen related to this is GSroot.dll not found. AC13 will not run without it. If you look in the Archicad 13 folder (windows), you see sure enough that it's not where it should be, but not only that, there should be a list of files as long as your arm in there, but you see only a handful.
Installed the newest upgrade for Archicad 13 which is Hotfix: Build 3600. After I installed it, when I try to load Archicad 13, it gives me the following error message, and Archicad will not load:
?_PrimaryServiceStateChanged@PresenceServiceObserver@TWCB@@MAEXW4VM@12@W4Value@PresenceState@2@@Z not found. Function is not available in TWClientBase.dll!
