Installation & update
SOLVED!
File / program association in Windows 11 (version 26)
Arcadia
I have both V25 & V26 installed. For no apparent reason windows (after latest windows update) has suddenly decided that all .pln files are a mystery to it and does not even recognize V26 as a possibility.
I can open files in V26 okay by using the open command in Archicad but I can't double click on the file in explorer to open it (I just get a message that this file does not have any software associated with it). Even old V25 files won't open in V25 if I double click.
Using right click, properties and searching for a program to associate with the .pln doesn't work either. I can see V25 as an option but when I search for and select V26 it just defaults straight back to V25. I had this issue when I had V24 & V25 installed as well and solved it by uninstalling V24. I'm not quite ready to uninstall V25 - is there any other potential fix for this annoying issue?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
12 REPLIES 12
Robert, also consider that your step will restore file association to Ac26 for the PLN file format only.
You would have to do the same steps for all other Archicad-related file formats you want to be opened with AC26.
Lászó,
I think you only need to register 2-3 extensions at most. It is also a consideration that installation requires administrator rights.
In many places it is difficult and expensive to hire a system administrator to do this task which can be done independently and quickly.
4.1 - - -
That is a valid point.
Learn and get certified!
