Installation & update
Windows 7 OS
I am getting a new laptop to use with AC 14. When I looked at the recommended operating systems for use with AC 14 it just says Windows 7. Does it matter which version of Win 7 is used (Home Premium, Ultimate, or Professional)?
Thanks
1 REPLY 1
vistasp
Mark,
From the point of view of ArchiCAD, if you're thinking of using AC versions older than v.11 then you might want to look at Pro (which includes XP-mode). Other than that, Home Premium works perfectly well.
Pro also gives you the ability to join a server domain (used by large organisations), encrypt your file system, run a remote desktop server.
All I can suggest is that you go with 64-bit if the hardware supports it.
Good luck!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
