2012-07-23
06:02 PM
2023-05-11
10:47 AM
Noemi Balogh
2012-07-26 05:23 PM
Enrico wrote:Hi Enrico,
Karl, I appreciate your optimistic answer.
2012-07-27 07:27 AM
2012-07-27 06:13 PM
2012-07-30 08:28 AM
2012-07-30 08:40 AM
2012-07-30 08:43 AM
2012-08-02 03:09 PM
Enrico wrote:It was my pleasure to reply to you.
Sved, thank you for replying to my questions.
It sounds like you are doing a lot of work for ED*!.I have been the product manager of EcoDesigner since day 1.
I'll divide my own answer into three parts, and I hope I'll manage to be clear.
As far as EcoDesigner*, it sounds like it's going to be and actual dynamic energy simulator, something like Bentley TAS: is that so?
If yes, what kind of output is going to give? My experience with TAS is that the amount of data output is so large, that you need a dedicated software to be able to sort out what you actually need... (don't get me wrong: I cannot wait to try it!)EcoDesigner* will be a multiple thermal block, high end energy simulation tool, like TAS. Besides the detailed output in XLS format, though, it will also produce a customizable PDF, where users can select which chapters to include on the report sheets.
- ETA: when is it going to be available?Q4 this year, although not with full functionality, yet. A public announcement containing the details is coming out soon..
- €/$: how much is it going to cost?
- Shading: is ED* going to be able to calculate actual shading, based on the real geometry of the virtual building?
- Thermal bridges: I know most dynamic softwares do not take them into account. What about ED*?
- Internal heat gains: I'm guessing you'll be able to create custom profiles on hourly basis?
- Climate data: seen the improvement in EDbasic, I guess you'll be able to import custom site climate data from Meteonorm, right?
- Thermal comfort: is it going to be possible to evaluate comfort conditions in critical rooms under dynamic conditions in summer (much like what Daemmwerk does)? This would be super helpful to verify comfort condition in the Mediterranean climate.
- MEP integration: is ED* going to be integrated with the MEP modeler in any way?
Furthermore, some nice additions to the overall energy design would be:
- Integrated daylight analysis;
- Lighting design tool;
I know, but we would need integrated ray tracing or radiosity for that, inside AC first.
- CFD;
- Embodied energy calculation (you can add an extra field per fill type "embodied energy", and calculate the overall embodied energy of design options)Good idea! There's a little bit of something being developed for AC17 right now that will be a perfect starting point for such developments...
2012-08-02 05:36 PM
2012-08-03 04:09 AM
2012-08-03 12:16 PM
Enrico wrote:I believe it's condensation that kills the Passivhauses in hot, wet places. Maybe if you re-consider the position of the vapor barrier relative to the super-insulation it works but I've seen some horrible failures from places like Florida. You practice in warm, dry climate, right?
As far as the PHPP:
I partially agree with what you say: the PHPP is only accurate with highly efficient, airtight envelopes, with a limited glazing-to-opaque-surfaces ratio. One more limitation is the fixed value for non-residential interior heat gains.
As far as I know, its accuracy does not depend on the climate. You may argue that the passive house concept does not work in warm climates: I can assure you it does (passive houses is actually part of my job here in Italy).
I think the PHPP is a valid and rather quick design instrument (once you import the envelope data into the spreadsheet, hence my question about the data export feature). I agree that in warm climates, the PHPP calculation must me integrated with a dynamic analysis to avoid discomfort peaks.
As far as data export from ED*, is the software going to export the same data as the previous version, or more? Version #15 was ok, but it did not export data about window frame geometry, shading etc.It'll export more (e.g. frame geometry including perimeter length)
