CarlsonWang
Can I edit material catalog?
Hi everyone,
I  want to calculate the embodied carbon from my model, and I am trying to edit the building materials' physical properties.
As I know, the material catalog can load the physical properties, but the data is unsuitable for our country.
Can I edit the material catalog directly? or I can load it from my catalog.
it would be appreciated if anyone could provide a solution.
10 Replies 10
Erwin Edel
You can just open it in Notepad, it looks pretty straight forward with 'tags'. Should be easy enough to create your own list.
Our version has a pretty extensive list, but the local reseller here (Kubus) generally goes above and beyond with most things.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
