2022-04-27 09:36 PM - last edited on 2022-09-30 02:01 PM by Oleksandra Vakariuk
Hi everyone,
It is impossible to use 'Apply View' (when someone requests an item or sends a message with a certain view) and 'Show' (My Workspace) commands in this Archicad version, it always ends up with a bug report. Has anyone run into the same problem?
2022-04-28 08:22 AM
Likely Archicad is running into an issue while trying to redraw the view. It can be due to some corrupted elements (stairs, railings for example), or there can be a problem even with the local cache. Depending on how many members are affected, it worth to start with a re-join / reload from server to clean the local cache then if it still occurs, save a PLN, open & repair and re-share this project.
It is possible that none of this will work, but then I suggest to collect a Support Package and the crash IDs and send it to your local technical support, so they can investigate it and help you fix the problem.
Noémi Balogh
Community Expert, Admin
