Teamwork & BIMcloud
Archicad 18 Bim Server "Address"
This is probably dumb - but where do I find what my BIM server Address is so I can enter that into ArchiCad so I can share my project in Teamwork?
37 REPLIES 37
Eduardo Rolon
Based on the screenshots that is the correct procedure. Next steps is to hit Start and configure the server.
One item to take in consideration is that you need a "Fixed IP address" in the for ox XXX.XXX.XXX.XXX if you computer is using a dynamic address then you every time it changes you will need to re-configure the BimServer.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
You are not finishing the setup process. When configuring the Bimserver by clicking on start you will be prompted to create an ADMINISTRATIVE ACCOUNT which is the user name and password that you will use to log in when clicking the BimServer icon. Also you will need to register your bimserver and for that you need the GS account.
Please look at the videos that Lazlo linked to in the first page of this post.
AC27 US/INT -> AC08
another Moderator
Ejrolon, Finaly...i found the solution....
The problem so simple indeed...that is because of my default browser..
so my step is :
01. Uninstall another browser
02. Change IE (Internet Explorer) as my default browser
03. After hit "START" then configuration page for new administrator user appear in IE browser successfully...
After that i can install another fav browser....n run my BIM server
Big thanks for ur answer n time Ejrolon...................................
Haneef Tayob
Fixed IP Address - Good advice. Our server was set to dynamic address when we did the installation. When our rooter or server rebooted after 3 days, we couldn't log in, even when we found out the new dynamic address.
It was almost a disaster. Had to reinstall Bimserver 18. Fortunately the automatic backups were intact, so we did not lose much work.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
