2010-09-01 05:02 PM
2010-10-04 03:37 PM
2010-10-05 11:32 AM
2010-10-06 01:01 AM
owen wrote:Owen
There is also another possibly-related problem we have also been experiencing in 14 - missing objects from loaded libraries. The libraries seem to load, however many (or all) objects from those libraries are listed as missing and do not display (other than as black dots).
2010-10-06 01:43 PM
2010-10-06 10:28 PM
2010-10-07 02:11 AM
KenMcN wrote:The path to any of our files would be quite long .. hard to say if it could be a problem though without knowing what (if any) limit there is. I wasn't aware of one.
Is there any chance your library is exceeding this limit (whatever length it is), but not displaying this error message as you are not working remotely?
This may account for the first parts of the library being available, but some nested folders not loading
2010-10-07 09:27 AM
owen wrote:You're right Owen, the files don't get synced across and work fine if they are manually copied (which we've also had to resort to).
…So the problem is with BIM Server libraries - I suspect specifically with how they are (or not in this case) syncing with your local cached libraries. I have looked into the local cache libraries and the object files are not there - yet they are on the BIM Server copy of the library. Something is obviously not working with this sync process and so not all objects are being copied locally.
One very dodgy, very temporary workaround is to copy the missing objects directly into your local cache library from the server.
2010-10-07 03:08 PM
another Moderator
2010-10-07 10:12 PM
2010-10-07 10:27 PM
