Teamwork & BIMcloud
Bimcloud 2024.3 some ldap users are "denied" after login
markom
Bimcloud is local, not SaaS. Ldap sync has been used for years, only after 2024 installation the problem appeared for some users. Few of them did not meet the password requirements, but even after they changed their passwords they are denied access.
20 REPLIES 20
Have you tried contacting Graphisoft about this? I am kind of stuck because as education institute I have to contact thru local reseller and for some reason the matter does not seem to go forward.
tkrepler_fjc
Oh, yes, of course. They had a look at all sorts of logs and suggested it is a problem with our LDAP setup. But nothing seems to be untoward there. LDAP logs show no problems (and you can log in with the same LDAP-account to the BIMcloud via the web interface, and the email and server connection are uninterrupted as well).
So, they found this thread just yesterday and said we are not alone, and maybe it needs more investigation on their side. They also suggested I have a look at this conversation as well, and maybe I find something here.
Tony Krepler
Design Technology Lead - BIM, fjcstudio
Sydney, Australia
Archicad since 3.4, macOS 14
torben_wadlinger
Hey guys, I've got an answer from the German Support, which was really helpfull (there is one single guy at German GS Support who is excellent). Here is his answer:
Hello Mr Wadlinger,
that does sound a bit unusual, but it could possibly have something to do with the way Archicad connects to the BIMcloud.
From Archicad 27 onwards, a so-called ‘modern or new authentication method’ is used in the case of BIMcloud Software as a Service; if you want to work with Archicad 26 and lower, you have to switch to the so-called ‘legacy authentication method’.
This means that there is a difference in the way Archicad 26 and lower and 27 and higher connect to the BIMcloud.
See e.g.
Working with older versions of Archicad and DDScad
https://help.graphisoft.com/BCSAAS/GER/index.htm#t=Topics%2FSaaS_Licensing_topics%2FLegacyAuthentica...
Work with older versions of Archicad and DDScad
https://help.graphisoft.com/BCSAAS/INT/Topics/SaaS_Licensing_topics/LegacyAuthentication.html
We have on-prem Bim server so there are not those options in General Settings..
tkrepler_fjc
Yes, same here. I think this is a unique setting in BIMcloud Basic — perhaps it should be in the on-prem BIMcloud (Pro) as well?
Tony Krepler
Sydney, Australia
Hopefully in the 2024.4 update:)
torben_wadlinger
Sorry, just translated the answer without really looking at the PDF's, because I got it working. After reading I realized that the content of the PDF's didn't match with the problem, well, it does in some kind, but there is no such option to switch between different auth-methods.
That's a bummer.
More like the 2025.4 update. 😐
Tony Krepler
Sydney, Australia
tkrepler_fjc
We received a workaround from Graphisoft, which involves stopping the BIMcloud Manager and editing the PortalServer.config file.
As our BIMcloud is used day and night, this change has to be made over the weekend.
The "denied" issue is sporadic, but I'll let you know how we go.
Tony Krepler
Sydney, Australia
Can you attach the workaround?
