Narska
Hotlink problems
I have a complex model file with about ten hotlinks in it.
Some of the hotlinks revert to previous pre-update versions when other hotlinks are updated. This happens on a regular basis. I update a hotlink and another one reverses it previous update unexplicitlySeems like some kind of bug. Has anyone ever had this happen?
Tomasz Mlynarski
New York based Architect
1 Reply 1
Gerry Leonor
that sounds like an odd kind of bug.
  • how are you exporting your modules? are you using the Publisher to export multiple .MOD files?
  • are they exporting to the same location? like 1 folder housing ALL hotlink modules (.MOD)
  • what sort of elements are being exported to an older version? Objects? Walls? Beams? Roofs etc? are some of them showing up in multiple stories (above or below)
https://discord.gg/XGHjyvutt8
